Maximum tyres for a standard sj410?
Phillips321
Post by Phillips321 » Wed Apr 20, 2016 11:01 pm
Hi guys,
Got a sj410 and tested it tonight by taking it up the motocross track, it did really well until the tyres turned into slicks! :hahaha:
I want to change the tyres to something more suited to off road.
I've looked the the stickied thread here but there was no definitive answer:
http://forum.suzukiclubuk.co.uk/vi ... f=12&t=226
I have 15 inch rims and currently 195/75r15.
The reason i want to go bigger is to get that little extra ground clearance.
Also any pointers on where's the cheapest place to get them from I would appreciate it.
P.s. I want cheap, not something that will last 40,000 miles!
Re: Maximum tyres for a standard sj410?
Post by ScottieJ » Wed Apr 20, 2016 11:15 pm
215/75r15 fit with no mods and 235/75r15 will fit with some slight trimming to the bumper mounts and you might also have to limit the steering a tiny bit depending on the tyres.
Maxxis bighorn tyres are cheap for a premium brand, not much more than a lot of remoulds tbh.
SherwoodNash
Post by SherwoodNash » Wed Apr 20, 2016 11:20 pm
Have you considered remoulds from http://www.camskill.co.uk ?
Insa Turbo Tyres / SUV 4x4 / Insa Turbo Sahara - 195/80 R15 96Q TL £58.90 inc.VAT
Phillips321
Post by Phillips321 » Sat Apr 23, 2016 6:04 pm
Thanks for the help guys,
Would a 30 9.5 r15 fit a standard? I've seen some local and cheap.
Matt
Post by Matt » Sat Apr 23, 2016 9:17 pm
235/75/15s usually measure around 29-30" so that should give you a good idea
1987 - Suzuki sj410q
31" Maxxis MT764 Bighorns
Winch & winch bumper
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
http://www.youtube.com/user/Matt270498
Post by ScottieJ » Sun Apr 24, 2016 8:52 am
Phillips321 wrote:Thanks for the help guys,
With some trimming and the steering lock limited they might.
Post by twiss » Sun Apr 24, 2016 2:20 pm
Courior has about 1.5" lift and spacers and 30x9.5s...
Plenty of upward travel space, but as scott says you might need to limit the steering lock without spacers
