Brake Drum not fitting back on ( Despite adjusting screw )
RocFreya
Post by RocFreya » Fri Aug 28, 2015 3:12 pm
Just replaced my rear wheel cylinder with a a TVS-girling from India. ( Only part I could find reasonably price-shipped to the US )
Replaced the shoes with new ones designed for a 86' Samurai. ( Only ones I could find so far, & seem to be the exact same size as my old shoes. Not 100% on the actual pad thickness though )
Still, the drum is a long ways off from fitting back on.
Drum doesn't have a lip. Self adjusting screw is set to maximum closed.
Thinking about getting the whole drum reamed out if I can't get this thing back on. Seems like if I have to do this again, a reamed drum will help fit my misfit parts.
Just don't understand why I having so much trouble in the first place.
84 Suzuki SJ410 ( North American Model )
Re: Brake Drum not fitting back on ( Despite adjusting screw
Post by ROBBIE » Fri Aug 28, 2015 3:29 pm
Are the pistons fully in the cylinder?
RocFreya
Post by RocFreya » Fri Aug 28, 2015 4:47 pm
Just looked and the new shoes are different in ways not apparent before.
Samurai shoes are more pronounced where they meet with the upper & lower wheel cylinders.
Currently doing some grinding modification.
RocFreya
Post by RocFreya » Fri Aug 28, 2015 11:30 pm
Grinded off the edges that were too wide. now they fit, " good enough "
