Propshafts
Modified
Propshafts
Post by Modified » Sun Jun 07, 2015 6:00 pm
What other prop shafts will fit an Sj? As need stronger ones because I am running 38" tyres, cheers
Re: Propshafts
Post by ScottieJ » Mon Jun 08, 2015 8:49 am
Modified wrote:What other prop shafts will fit an Sj? As need stronger ones because I am running 38" tyres, cheers
If the gearing is set up correctly there should be no need to upgrade propshafts.
Custom props are the only option other than standard. Shortened Toyota props are common swaps.
steve greenc3
Re: Propshafts
Post by steve greenc3 » Mon Jun 08, 2015 11:00 pm
Are you building this truck from scratch?
