I bought this truck as a standard vehicle in 2002 and have been modifying it ever since
I have been competing with this truck for most of this time and it has evolved into what you see in the
pictures it has had many class wins
I also had series wins in the last few years
this truck has been great fun to compete with but the time has come to try a new vehicle
so this one is up for sale
bellow is the vehicle spec
The chassis is a sj413 that has been strengthened
The rear cross member has been replaced with 4x2 box section
The rear cab cross member has also been replaced with 4x2 box
And then fitted with mounts for land rover trailing arms and roll cage mounts
Cab is a LWB truck cab fitted to chassis with 3" body lift
also fitted with jackable rock/tree sliders
Winch switch and wiring included for front winch
Engine is a 1300 sj engine fitted with a 44hif su carb and straight through exhaust
Just had low mileage replacement engine fitted with new cambelt/clutch
an electric fuel pump and high output alternator
gearbox is sj413
transfer box is a rock lobster so 4.16:1 ratio fitted with x-eng handbrake
and mounted on l/rover series 1 engine mounts
front axle is samurai with spoa perches moved to match sj413 chassis
fitted with vitara ring gear and pinion 5.125:1 ratio
prop spacer on front prop front suspension is spring over axle with de-flex shackles
and softened iron man springs with 4" extended shocks 1 spare included
rear axle is samurai axle modified to take coil springs
axle strengthened to prevent bending
rear suspension is home devised but works!!!
springs are vitara fronts shocks are rough country + 8" set at 45degrees 2 spares included
axle held by discovery 300tdi trailing arms and land rover rear A frame
axles/transfer box and gear box connected by high level breather
front winch bumper is a one off made for the truck to fit a Warn 8274-50
winch plate on rear to take low line winch with 2 recovery hooks
vehicle has a full roll cage complete with tray back fitted with 4 front spots and
two rear spots also has large storage box
1 set of waffle board holders including pair 38mm waffles on the rear tray
The wheels are grand vitara deep dish 16"
tyres are 265/75r16 insa turbo special tracks these are as new depth as never used on the road
There are three batteries fitted to the truck two under the bonnet and one
In the back under the trayback
Fuel tank is under the trayback and has custom filler and breather with filter
front winch is a Warn 8274-50 fitted with Bowmotor 2 and synthetic rope available at extra cost
winch has just been serviced and gears are all in excellent condition
THE WINCH IS NOT FOR SALE SEPARATELY UNTIL THE TRUCK HAS BEEN SOLD AS THE BUYER HAS FIRST REFUSAL
This vehicle is advertised elsewhere so may remove at any-time
Any other questions just ask
forgot to say truck as had a recent radiator and has an electric fan fitted
will also come with a plate and pins ground anchor
a snatch block and D-shackle
and a couple of tree strops
Looking for £2100 without winch
£2800 with the winch
truck is in Devon
Trayback zuk for sale
highly modded sj with 1400 rti score
