VOLTAGE REGULATOR FOR GAUGES 413
basil
Post by basil » Sun Mar 15, 2015 1:11 pm
Does anyone know if the voltage regulator IF IT HAS ONE for the gauges which i presume is behind the speedo binacle... does it have a bearing on the fuel gauge and the temperature gauge....
i have just taken offside wheel off and waggled the lead which goes to the tank sensor tag sprayed it with wd40.did not pull it off as i would not be able to replace it .very restricted access ...but on lowering the anus it appears to be reading quite high.......
Could be i guess the variable type resistor track is worn ??? or dirty on tank sensor.....
As Redex is fairly well thought of as a cleaner perhaps some added to the tank might work its way onto the sender (I KNOW GRASPING AT STRAWS)
Just noticed i have got oil on my new shirt, rhymes with clucking bell
Where did my wife put that bottle of Brandy.......
Jim
basil
Re: VOLTAGE REGULATOR FOR GAUGES 413
Post by basil » Tue Mar 17, 2015 2:45 pm
The continuing story ......just removed most of the rear carpet and there appears to be a panel above fuel tank ..its not bolted down but looks as if there is a black bituminous compound around the outside Could this be a access panel to the fuel gauge SENDER ? should i try to prise this panel up it looks well stuck down...WERE THE JAP JEEPS MADE DIFFERENT TO THE SPANISH ONES
JIM
Post by ScottieJ » Tue Mar 17, 2015 2:59 pm
Do you have a picture? I've never know any SJs to have a hatch from the factory.
basil
Post by basil » Tue Mar 17, 2015 3:16 pm
Will remove the rest of the carpet tomorrow and take a picture the wife is off in the anus so i will have to wait....it appears to be directly above the sender...
jim
Post by twiss » Tue Mar 17, 2015 6:57 pm
I would tell her to go to the doctor about that lol
basil
Post by basil » Tue Mar 17, 2015 7:29 pm
EVERY TIME I TYPE anus THAT WORD REPLACES IT
JIM
Ladaman
Post by Ladaman » Tue Mar 17, 2015 8:33 pm
Well let that be a lesson to you. Don't use that word, as you vehicle isn't a ****! ;)
Post by ScottieJ » Tue Mar 17, 2015 9:46 pm
:hahaha: you can blame Twiss for that
basil
Post by basil » Wed Mar 18, 2015 9:08 am
Well removed all the stuck down carpet and you guessed it no panels to remove......
ages putting it all back together..........so its going to be tank out at sometime on the anus
when fuel is much lower.........
Jim
