A lot of wiring
lukey4x4
A lot of wiring
Post by lukey4x4 » Wed Feb 25, 2015 6:57 pm
Hi i am planning on putting my c reg sj back on the road but after fitting the vit engine and loom i have no lights ,brake lights , indicators, wipers, no fuel gauge , hazzards ,speedo, basically nothing electrical lol not to fussed about heating working though ,, so if anyone can help ,
And Would it be worth buying the vitara clocks thanks
timwilks13
SCUK Website Padawan
Re: A lot of wiring
Post by timwilks13 » Wed Feb 25, 2015 7:56 pm
How much of the original loom has been ripped out? Speedo comes from the tranny box so that shouldnt change. Everything else i would advise seeing what you have, what is still wired up, then being the fun tedious task of following each wire, grab a wiring diagram and crack on.
RickUK
Re: A lot of wiring
Post by RickUK » Wed Feb 25, 2015 8:00 pm
I have no idea about wiring or even suggesting what to do,just hope you are not colour blind :lol:
Deceased.
Current wheels.
lukey4x4
Re: A lot of wiring
Post by lukey4x4 » Wed Feb 25, 2015 8:09 pm
All the old wiring is still under the dash mate , i only cut out what was in the engine bay lyk , ano its gunna be a nightmare lol finding what goes where
Re: A lot of wiring
Post by ScottieJ » Wed Feb 25, 2015 9:35 pm
You cut out the wiring in the engine bay??? That was a mistake as you use that to wire the 1.6 up. There's only one wire that you don't use from the 410 loom if it's a carb engine that you fitted.
Chances are you have cut out the main power feed for everything, it's a thick white wire with yellow tracer.
lukey4x4
Re: A lot of wiring
Post by lukey4x4 » Wed Feb 25, 2015 9:41 pm
Yea mate when i put the 1.6 spi in i just used the vitara loom and cut the 1.0 wiring out i have the engine and that running just need to sort the rest out
Re: A lot of wiring
Post by ScottieJ » Wed Feb 25, 2015 9:55 pm
Look for the white and yellow wire from the loom you cut out, you'll need to wire that back up.
There could be more that you need without knowing exactly how you have wired the vit loom in. Was quite a silly move just cutting it all out before checking what you needed to keep first.
lukey4x4
Re: A lot of wiring
Post by lukey4x4 » Wed Feb 25, 2015 10:58 pm
Ok mate will have a look tomoz when a put engine in a wasnt planning on putting on the road but i will pay for it now l thanks
lukey4x4
Re: A lot of wiring
Post by lukey4x4 » Thu Feb 26, 2015 7:41 pm
Gunna give this a go tomoz , so just checking if i find the plug off my vit loom that connects to the indicators and lights unit could i cut the connector off and some how wire it to my original sj wires or is it diffrent ? Thanks.
