Need specs/part numbers for oxygen sensors - GV 2009 2.0l
Posted: Mon Jan 26, 2015 7:30 pm
Hi lads,
I am from Brazil and I have a Suzuki Grand Vitara 2.0l, petrol, engine J20A. Matter of fact is that my first heated oxygen sensor (the one between engine and catalytic conversor) is not working properly and I need to find a replacement.
The original one sold from Suzuki is 3 to 4 times more expensive than the alternatives in the market. My issue is to find out which of the alternative, generic sensors, will work for me. Suzuki does not seem to agree that they should give me the part number so that I can find an alternative and be sure that it will work.
So my questions are: which is the part number for the first ho2 sensor? Do you know of a direct match from a global vendor (like Bosch)? Is it the same as for the SX4 (which has the same engine here as far as I know)?
Thanks in advance from a desperate owner
