G box to Pug 1.9TD enigne?
waynesworld
Post by waynesworld » Mon Dec 15, 2014 8:27 pm
Can we have a list please of RWD gear boxs that will mate up with the Pug 1.9TD engines, not using an adaptor plate, all but the LDV Pilot G box as the gearing is no good, been there and done that.
cheers all
wolly
Very Happy
Re: G box to Pug 1.9TD enigne?
Post by Anton » Tue Dec 16, 2014 7:16 pm
I'd look into diesel vitaras. Not grand vitaras - but original vits - I'm fairly sure they had pug 1.9 NA's out of the factory, so they should mate up. Built in t-case too, should simplify your dutton build.
Post by ScottieJ » Tue Dec 16, 2014 7:18 pm
Not hard to convert to run an SJ Tbox either.
d_r_1989
Post by d_r_1989 » Tue Dec 16, 2014 9:01 pm
The commercial vitara had the xud engine so a commercial gearbox will fit and have a longer ratio but they run 4.8 diffs so could be quite long with a 3.74 or 3.94 diff.
Post by Anton » Tue Dec 16, 2014 11:17 pm
The Vit diffs are geared to their tcase being 1:1 high. Samurai tcases are 1:1.4(ish) and 410 cases are 1:1.6(ish).
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2947
Mixing and matching parts, you may find that you can get a range that suits your needs.
If the Vit commercials have odd ratios, look into getting a Vit gearbox and a Vitara diesel bellhousing as I believe they separate - you may find you can swap the bellhousing onto another gearbox that suits you more.
d_r_1989
Post by d_r_1989 » Wed Dec 17, 2014 8:42 pm
Vitara gbox and bell housings separate very easily, but they are pricey as people want the bell housings.
Post by Anton » Wed Dec 17, 2014 8:58 pm
You may have to consider making an adapter plate or modifying a bellhousing then...
d_r_1989
Post by d_r_1989 » Wed Dec 17, 2014 9:07 pm
My gbox is a samurai box with modified bell housing and works well.
waynesworld
Post by waynesworld » Sat Jan 03, 2015 1:01 pm
Hi Daryl, that was you then on that other slooooow forum lol.
Be interesting to see how your is converted then mate, and how it drives on road. If i can i will pop up when you change your clutch, when you planning it mate. In no rush as getting bits together and lots to to on another kit car yet. weather is holding me back now.
Post by Anton » Sat Jan 03, 2015 1:14 pm
d_r_1989 wrote:My gbox is a samurai box with modified bell housing and works well.
Just out of interest, got a build thread or pics of the bellhousing mods?
I'm interested in how it was done, what clutch you used etc.
