Locking rear diff.
1066 Boy
Locking rear diff.
Post by 1066 Boy » Fri Oct 17, 2014 7:20 pm
Hi all, i have a lock-right rear diff lock. Its in with the other spare bits that
comes with the car. If i dont use it and want to sell it, whats it worth? :er:
I Know how to work it. Not, how it works...............
believe me, there is a difference!!!
Re: Locking rear diff.
Post by twiss » Sat Oct 18, 2014 9:46 am
Jimnybits charge £226 for them new
1066 Boy
Post by 1066 Boy » Sat Oct 18, 2014 4:51 pm
Thanks for that Twiss. So would £100 be to much s/hand :?:
I dont want to take the p**s but i dont need it. :thumbup:
Post by Anton » Fri Oct 24, 2014 2:27 pm
£100, if it's new, is taking the p**s - I would say £150 is more fair unless you want rid of it fast.
1066 Boy
Post by 1066 Boy » Fri Oct 24, 2014 7:25 pm
I have the locking rear diff and the front one in the same ratio.
I want to get rid of the pair so open to offers. :thumbup:
Post by Anton » Fri Oct 24, 2014 7:55 pm
What's the ratio? And I assume the front is an open diff?
1066 Boy
Post by 1066 Boy » Fri Oct 24, 2014 8:33 pm
Yes the front is a normal diff. lock-right rear.
Not a clue about the ratio's as i am new to all this. :S
Post by Anton » Fri Oct 24, 2014 8:41 pm
Mark a spot on the Crown wheel and a spot on the pinion. Slowly rotate the diff and count the number of teeth on each. Divide the number of teeth on the Crown wheel by the number of teeth on the pinion.
That's your ratio.
You'll have a tough time selling them without knowing the ratios.
1066 Boy
Post by 1066 Boy » Fri Oct 24, 2014 8:45 pm
Thanks for that, i'll have a look at the weekend.
I am not that savvi with things like this but i'll have a go. :salute:
1066 Boy
Post by 1066 Boy » Sat Oct 25, 2014 2:30 pm
Ok job done. They are 3.9's. :salute:
