Got all the bits and motor factor supplied me 5 litre of red OAT coolant where previously it had green in .
Will the red be ok ? I did ask the factor and he says everybody uses it now when doing total coolant out jobs . Wondered if older engines preferred old style blue ?
Thanks for any advice .
Also can you advise me , do I slacken the four bolts on the pulley before removing drive belt to swap the pulley over on the new pump ? , I ask as haven't got pump yet and ones ive seen on tinternet show it without pulley ?
thanx
Ian
