odd problem with sound system
courior
Post by courior » Sun Sep 14, 2014 4:01 pm
Hi all.
Current setup i have is as follows... I have a Pioneer head unit feeding 2 normal car speakers in the footwell (this on its own works great) ... But i wanted some rear speakers and a bit of bass so i got an old but powerful 2.1 computer sound system and removed the transformer and wired it up to take 12V. Mounted it all in the car and when i plug my phone/mp3 player to the input jack (that would usually go onto the pc) it sounds perfect!
Problem comes when i attach the input on the 2.1 system to the RCA PRE-AMP output on the head unit. When its at low volume the 2.1 speakers hiss and pop randomly... but when i crank it up it sounds great! (ok so workaround is to always have it at 100% volume, but thats not practical is it :) ) ... What could be causing this? my immediate thought was that i got the + and - mixed up from the 2.1 sound system, but then surely it would hiss and pop with no input or a low input from my phone also?
There is no special settings on the head unit i can find, and i have plugged it into the FRONT pre amp out not the sub output. Any ICE experts have any ideas?
Cheers,
Courior
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: odd problem with sound system
Post by Anton » Sun Sep 14, 2014 7:11 pm
Maybe it's picking up electric noise from the SJ's electrics via the ground on the speaker input/pre-amp out?
Wire up headphones to that output and see if you get the same problem.
Post by Edweird » Mon Sep 15, 2014 1:39 pm
I agree, it could be ignition noise. You might need to put a hefty capacitor across the system's power supply.
courior
Post by courior » Mon Sep 15, 2014 6:03 pm
Forgot to add. This is with no ignition. Just the key in the acc position. And also happens with the motor started. I've been reading and I think its to do with the voltages supplied by the headunit over the pre amp out.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by Edweird » Mon Sep 15, 2014 9:04 pm
Okay, scratch what I said. it sound like it's a gain issue then. not sure if you can but is there some way of reducing the gain on the 2.1 system and increasing in on the preamp?
Post by dan_2k_uk » Mon Sep 15, 2014 11:44 pm
Don't think I've ever seen any options to do with preouts on any head units I've ever had. Easy quick solution if you only ever listen to music from your phone would be to use a splitter to connect the phone jack to both at the same time. No good if you wanted radio or CD though.
