MG410 Noisy fan
courior
MG410 Noisy fan
Post by courior » Sat Aug 23, 2014 12:27 am
Hi all,
I have the F10A motor in a Maruti, it used to have really noisy tappets so couldn't really hear much else while it was running.. But anyway sorted that and now there is a new noise when i get above about 2k rpm.. i thought it was the running gear as it sounds like a rumbling bearing but more plasticy (if thats even a word), but i realised it did it sitting still revving on the spot.. Upon inspection it seems like the fan is making this noise. I thought it was the shroud but thats tight and doesnt make a noise if u wobble it. So its gotta be the fan itself. The bolts that hold it in are all done up, and the belt is the correct tension, it doesnt look damaged etc.. The noise is loud enough to hear while driving with the windows open though and really get on my t*ts.
So my Questions:
1.Is this a normal noise? (i never had a car with a constant fan before)
2.Can it be bodged to be more quiet?
3.Should i maybe go for an electric fan?
Cheers all!!
Courior
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: MG410 Noisy fan
Post by Edweird » Sat Aug 23, 2014 2:00 am
I've never noticed my fan making a 'plasticy' noise. You do hear is blowing air around a lot if you rev the engine when stationary but driving along the road noise, engine noise and my stereo drown it out.
courior
Re: MG410 Noisy fan
Post by courior » Wed Sep 03, 2014 4:00 pm
Just to give this thread a bit of closure... I sorted out the problem today!
The noise now had become so loud it was heard over the stereo and road noise. So drove it into my garage and started prodding bits of engine with it running at fast idle (where it was loudest) to see if i could find the culprit.. And i did.. It was the cam belt cover. it was rattling against the head of the motor. So i took off the rad (swung it out the way) and in the process snapped a bolt that hold the rad bracket on. Took off the fan and the bottom pully and removed the front half of the cover. Then i found that the bolt on the right that bolts the cover to the head was a bit loose. When i tried to tighten it up it just spun, so the previous owner must of stripped the thread when they put a new head on it. The good news is that the cam belt looked new and i managed to bodge it up with some rubber so now the cam cover is solid as a rock. Put it all back together and the motor is silky smooth and whisper quiet! To get the snapped bolt out, there was 2/3 turns of thread poking out of the mount, so i screwed on a bolt and plug welded the nut to the stud and voila it came right out.
2 Little questions for those who have read this far :) ... 1) do the bolts that hold the cam cover on go deep into the motor so much they can leak oil?
2) The big accessorry crank pully, i did it up VERY tight (no torque wrench)... is this something i should do again with a torque wrench to be sure?
Cheers,
Courior
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: MG410 Noisy fan
Post by ROBBIE » Wed Sep 03, 2014 7:46 pm
1 I would say no
2 I just did as tight as I could
courior
Re: MG410 Noisy fan
Post by courior » Thu Sep 04, 2014 12:33 pm
OK great. That's what I did just as tight as I could. Done a few miles today. Seems ok :) and oh so quiet than before.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
