cant open the door from the inside but i can from outside?
Jordanquin
Post by Jordanquin » Wed Jul 30, 2014 7:37 pm
whats the best solution to this problem as it opens fine from the outside without any problems?
ive had a look at the door locks and they line up fine else the door wouldnt open at all?
Re: cant open the door from the inside but i can from outsid
Post by ROBBIE » Wed Jul 30, 2014 8:19 pm
Take the door card off and check that there are no broken connectors
Jordanquin
Post by Jordanquin » Wed Jul 30, 2014 8:53 pm
Right ok mate I'll have a look at that, is there any other solutions if there are not any broken connectors or will I have to get a whole new mechanism?
Post by ROBBIE » Thu Jul 31, 2014 8:24 am
Should be metal linkages with plastic clips, from memory, should be an adjuster in there somwhere
Post by twiss » Thu Jul 31, 2014 8:40 am
You might get lucky and just have to pop the metal bar back into the handle
Jordanquin
Post by Jordanquin » Sat Aug 02, 2014 8:54 pm
Oh right, I will have a look at this then. And also the windows go up and down fine but the rubber has become bent inwards and has stopped it going so far up, what's the best solution to remould them back so it goes up and down smoothly??
