Page 1 of 3
new springs :-D
Posted: Wed Apr 16, 2014 9:06 pm
by Izuki
Got my new Springs delivered today. Cant wait to get them fitted (hopefully this weekend).
sorry for the rubbish photo will try and get a better one before I fit them.
Re: new springs :-D
Posted: Wed Apr 16, 2014 9:40 pm
by Ladaman
Nice.
Where did you get those from?
Re: new springs :-D
Posted: Wed Apr 16, 2014 9:41 pm
haha I was just typing the same thing
Re: new springs :-D
Posted: Wed Apr 16, 2014 9:51 pm
by Izuki
Ordered them from a company called midland road springs. They have a two inch increase in camber over standard springs and were very well priced and only took about a week from order to delivery.
Re: new springs :-D
Posted: Wed Apr 16, 2014 10:37 pm
by Darrell
Izuki wrote:Got my new Springs delivered today. Cant wait to get them fitted (hopefully this weekend).
You may need an angle grinder and some new bolts, so may be worth checking availability before starting the job
They are 100mm x 12mm.
Re: new springs :-D
Posted: Wed Apr 16, 2014 10:43 pm
by Izuki
Hopefully it won't be an issue my u bolts are in fairly good nick as I've had my axles off a few times while I've owned the truck.
Re: new springs :-D
Posted: Wed Apr 16, 2014 10:48 pm
by Darrell
I'm referring to the ones going through the bush, as these can often seize onto the sleeve.
You may get lucky
Re: new springs :-D
Posted: Wed Apr 16, 2014 10:58 pm
It's the spring mounts. The rubber bush has a steel sleeve in it which rusts to the bolt.
Re: new springs :-D
Posted: Thu Apr 17, 2014 12:11 pm
by Jay18
I had the same problem with the spring mount bolts rusting together with the sleeve, right pain a I didn't have any electric where the zuk was so had to hacksaw them off, was pretty lucky with the fronts though.
Glad you didn't buy them from japanese4x4spares, they're crap :/
Will be good to see some pics when you are done
Re: new springs :-D
Posted: Sun Apr 20, 2014 11:24 am
by Izuki
So started the sj rebuild/rejuvenation today. Here's how she looked before starting.
- 2014-04-19 16.31.18.jpg (1.13 MiB) Viewed 8829 times
Have made spring over axle perches to weld on so i can go back to standard length shackles but keep the same amount of lift for my 31's. Also considering making front shackle reverse does anyone have any photo's of a samurai with shackle reverse kit fitted?
- 2014-04-20 10.42.43.jpg (1.37 MiB) Viewed 8829 times
Picture of new rear MRS +2" spring vs old pro comp +2" rear spring. And also 2 broken u-bolts.... b*!!*cks. Think I must have cursed myself the other day d'oh.
Does anyone know a place to get reasonably priced u-bolts at short notice?
