In the past have used have used molyslip grease on the joints...molydeum disulphide i think its called
it tends to throw out after a while is there a better lubricant to use on these ????
Jim
propshaft grease ?????
Re: propshaft grease ?????
Suzuki recommend chassis grease. Whatever spec that is
. I've been using lithium based EP2 multi-purpose grease for the last 14 years because that what I keep in the grease gun at work
Just grease them regularly and It should be fine.
