my little project
Rhinoman
Re: my little project
Post by Rhinoman » Tue Jul 09, 2013 12:45 pm
stevepsj413 wrote:failed mot.
h/c emissions thru the roof
Did that carb come off a Samurai?
stevepsj413
Post by stevepsj413 » Tue Jul 09, 2013 8:44 pm
yeah i think so, its a weber 32/36 with the right size jets, had to make the air box adapter myself tho, thats why it looks a bit rough
Post by turbo-tom » Tue Jul 09, 2013 10:29 pm
you should be exempt from emissions! :er:
Post by Jordi » Tue Jul 09, 2013 10:35 pm
Mine was 0.18 on emissions. Just tested it for fun. The limit on those young enough to be tested is 3.50 i think.
Rhinoman
Post by Rhinoman » Tue Jul 09, 2013 10:35 pm
turbo-tom wrote:you should be exempt from emissions! :er:
Good point however its an M-Reg - wouldn't that have been EFI? in which case it will need to pass a cat test, if so then that would explain why its well over on hc. A carb model would only need to pass CO and visible smoke.
Post by dan_2k_uk » Tue Jul 09, 2013 10:37 pm
Thats what I was going to say.
2.5 instead of 3.5. Still perfectly achievable with the Webber.
Rhinoman
Post by Rhinoman » Tue Jul 09, 2013 10:45 pm
Checking the MOT manual it looks like it just squeezes into the non-cat test (up to 31 July 1995) which is 3.5% CO and 1200ppm HC
stevepsj413
Post by stevepsj413 » Tue Jul 09, 2013 11:57 pm
yeah i got an old mot here, it says co2 max limit is 3.50% and h/c max is 1200ppm so do you reckon if i put a cat in my exhaust it would be enough to bring the emissions down, i dont know exactly how high they were he just said the words "through the roof"....!? any ideas
Post by ScottieJ » Tue Jul 09, 2013 11:59 pm
They should have a printout at the garage of the readings.
Post by turbo-tom » Wed Jul 10, 2013 12:00 am
fitting a cat i would say to get it affective you probably would have to start running lamba sensors maybe.. i would invest in service and tune up of the carb and try again.
