Page 20 of 22
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 6:58 pm
by TanZuk
Since the rear end components were out for painting. This seemed to be a good time to get some ideas for a rear bumper. The usual mounting holes that seem to be used to secure the rear bumper were not available, since the rear shackles were moved back.
Here was my solution for this problem of mounts for the rear bumper. Used 1/4x2x3” rec tube and milled the sides down to slide fit in the Zuk frame. This was done to sleeve the inside of the Zuk rails and make for a stronger joint and alignment for welding. There was also a piece of ¼” welded to the under side of the mount and the rear shackle for side strength.
Here is my cardboard mock up and is a bit lager then most of the rear bumpers that are being made. Also wanted to use the round lights and they are 4 1/2” diameter. The reasoning behind this is that the Rig will see more street then trail and didn’t want anyone having a direct hit to the fuel tank. There will also be a removable step for rear entry for a single passenger, since there will only be a solo seat in the rear. Most important, doesn’t look like everyone else’s.
Should be installing the rear end this weekend and ordering material on Monday for the bumper.
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 6:59 pm
by TanZuk
Tweaking the rear bumper design.
This is a good example of using expendable materials when coming up with an idea for what you want to fab.
Decided to look at this bumper for a week to try and fine tune it a bit and make it a little easier to fab. The large radius were eliminated and angle plates will be substituted. There was also and addition of a center brake light bar and the 4” backup lights were changed to the 2”. Also fish plated and painted the bumper extensions.
Ordered up the metal and lights yesterday. Going to finish up painting a few more parts on the rear suspension and install it. This will get everything in one place to get ready for the projected storm for next week.
New Design
Old Design
Re: Zuk on 38's
by TanZuk
The rear axle is back in place to make some much needed working room. The construct of the pieces will be done on the Rig. This will be the welding jig to ensure proper fitment.
The license plate will be recessed along with the top brake light bar. This will keep them safe from an accidental hit when loading up of a rear passenger.
Here are a few pics of the start and the lights that will be used.
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 7:00 pm
by TanZuk
Got the center section machined out for the backup lights, recessed brake light bar and recessed license plate. The license plate recess has been made and welded to the center section. Need to order some more material for the outer pieces.
Re: Zuk on 38's
by TanZuk
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 7:01 pm
by TanZuk
As usual this bumper is also taking much longer to complete then anticipated. Did I mention it is getting extremely hot in the shop now. smokin
Still had some issues with the wings. Ended up resigning them a few more times to try and get a better transition line from the wheel flare to the 6.5” bumper end, without looking so awkward.
Here is what it ended up like and is tacked in place. There are 2 angles leaning towards the body. The top angle is 18* and the lower is 28*. This helps with tire clearance when suspension is compressed.
Here is the DS with the lights in to give you an idea what it will look like.
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 7:05 pm
by TanZuk
That's all I have got done to date. The rear bumper has had all the outer welds smoothed out and rounded all the edges. This bumper now looks like all the metal was bent instead of welded.
Going to send the bumper out to get LineX bed coating and tinted to match the rig.
Terry
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 7:26 pm
by dan_2k_uk
Tidy as always.
How are you planning on getting into it?
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 7:43 pm
by TanZuk
dan_2k_uk wrote:Tidy as always.
Thanks Dan,
This was part of my planning stage of the build. The most important was to take measurements of the shop door to make sure I could get it out. Next was how to get in since I’m no longer anywhere near 20ty any more.
That was the reason for the running boards.
I use the back tire for the 1st step to the running board and then in the door. Really not that bad. The back door passenger will have a removable 3 step bar that will attach to the back side of the bumper like a receiver hitch mount. Still in the planning stages.
Terry
Re: Zuk on 38's
Posted: Thu Sep 19, 2013 10:30 pm
by donkeychomp
Terry welcome back matey! Wondered what had become of you.
Love the work, as usual all top notch stuff.
Alex
ps interesting tag for a FLA anus!
