wiring diagram for the ignition barrell?
Jay18
Re: wiring diagram for the ignition barrell?
Post by Jay18 » Fri Sep 21, 2012 1:16 pm
i have that kit yes and im usuing the whole kit, im just working out how to do the immobiliser and hazard light flash when you arm and disarm the alarm, i have also ordered a central locking kit to fit to the SJ so it can be controlled by the alarm...
ive worked out what im doing with the immobiliser im just working out what im doing with the hazard light feature...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Post by Darrell » Fri Sep 21, 2012 1:40 pm
The problem with the hazard light switch is when activated it puts power to the indicator relay and connects both left and right sides together. As this unit only has the one wire supply I can't see how to make the hazards come on. Only one side or the other. You could add a couple of diodes that would make it work. Unless someone can see an easier way I've missed.
Jay18
Post by Jay18 » Fri Sep 21, 2012 2:06 pm
sound all very complicated, i might just buy some led strips and fit them so instead the leds will light up...
do you think i could fit some small strips of leds into the inicator lenses so it looks like the hazards flash, if not i could always put them somewhere else..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Darrell » Fri Sep 21, 2012 2:11 pm
Lot of fluffing about though. As you said any light will do just to let you know you've set it on/off.
indicator hazard.jpg (65.66 KiB) Viewed 7592 times
Post Edited due to relay idea being blooming useless :oops:
Jay18
Post by Jay18 » Fri Sep 21, 2012 2:14 pm
thanks for the help mate, i think i will just buy some leds and use them it seems alot easier lol..
and i like easy so i will do it that way, either put leds in the lenses of the indicators or put them somewhere else i will work that out today as im going over to my car today..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
