The buggy with no name
Re: The buggy with no name
Sorry for slow updates, the internet has been down at home for to to long!
Not much in the way of pictures, but a lot to tell you all about.
Firstly all of the tube work is finished. Cross in the roof, center piece down the screen. Rock sliders, floor, transmission tunnel done. All steering shortened and fitted.
Rear prop has now been shortened, plated up the back of the chassis where i cut the rails off.
I have started but plate up the front and rear bulk heads, but of a job as the front is a mixture of angles.
STILL TO DO
Fuel tank to make and fit
Brake lines to fit and bleed up
Fuel lines
Finish all plating
make new shock cones and fit new shocks.
And a whole lot more!
Henry
STILL TO DO
Fuel lines
Finish all plating
Henry
lookin really good.
if I was to do it I would use a big petrol just for the noise factor!
keep up the good work
Dan
Dan
My other hobbies include tractor pulling...
I can assure you that the 200 will be making a big noise, with some big boost and a lot of smoke!
More done over the last few days, Bought new brakes lines from dave at llama 4x4 and fitted them, +5 brit part shocks, still to fit, made a fuel tank, fitted fuel lines battery cables etc, fired up for the first time, sweet as a nut!
Henry
Henry
Good work henry.....hows the sj???
my ride.........
my ride.........
Broken, sitting at the back of the shed looking sorry for itself!
Dropped a bearing in the rocklobster
More progress today,
New front brake calipers fitted, along with all the new brake lines from Llama 4x4. Shocks Fitted and clutch and brakes all bled up.
Out for the first test run.... no clutch :(
Forced it into gear, took of down the yard, handbrake well and truly on, foot on the clutch, took of. After about 700 yards a big bang, clutch now free and fully working haha.
Backed it round the back of the shed, sheet over and water out over winter. I wont have a lot of time to do anything to it now, so park her up till next year.
Is it really that long ago since i posted on this thread!?
Anyway work has been happening over the last few days. Firstly i had to source some new rubber as i sold the diamonds over winter.
With that done we set about the rest.
Tray back built
PAS Done
All cab plate done, Bar round gear sticks
Roof
Start of rear tub
Seats in.
Now finally i can get it running and driving, took it out over a friends farm yesterday, the first time it got hot at the turbo is kaput, still works but throws a lot of smoke and oil out.
Now a few more silly jobs i overlooked finish plating, lights, clocks, paint.
Have a butchers Carnt embed it http://www.youtube.com/watch?v=h07sokpr ... e=youtu.be
Henry
Tray back built
PAS Done
Roof
Start of rear tub
Seats in.
Henry
