SJ410 -1985 'Cabrio', engine rebuild
binge
Re: SJ410 -1985 'Cabrio', engine rebuild
Post by binge » Wed Mar 19, 2014 5:24 pm
May be a silly question. Will a 1.3 head fit? Somebody suggested fitting one.
I have no idea as never seen a 1300cc head in the flesh.
Ta
Ben
Post by twiss » Wed Mar 19, 2014 5:45 pm
No they won't unfortunately
binge
Post by binge » Wed Mar 19, 2014 10:31 pm
Okay. Well just picked up a 1.3 engine with both manifolds and carb for 50£. Req a 1.3 flywheel and box now.
Post by twiss » Wed Mar 19, 2014 11:05 pm
Not bad! You will have to adapt the engine and gearbox mounts
binge
Post by binge » Thu Mar 20, 2014 6:50 am
Yeah? My SJ is not a skinny prop one.
binge
Post by binge » Thu Mar 20, 2014 9:29 am
Need a 413 flywheel and gearbox.
timwilks13
SCUK Website Padawan
Post by timwilks13 » Thu Mar 20, 2014 10:08 am
twiss wrote:Not bad! You will have to adapt the engine and gearbox mounts
when i put a 1.3 in my 410 its was just the engine mounts that needed moving, the gear box mounts were in the right place.
binge
Post by binge » Thu Mar 20, 2014 1:11 pm
Is it the cutting and re-welding to the chassis that is needed? Or is it just a mod to the mount.
As all the research I've done, has shown that you only need to move the mounts on the early 410s.
I have no issues either way, as I have all the fabricating stuff at work.
In regards to the box and F/W. Any ideas where I can get them?
Have a full 410 tin-top that I'm breaking if anyone needs any bits to swap. T-Box is already gone, but still have both axles etc.
Ben
timwilks13
Post by timwilks13 » Thu Mar 20, 2014 1:17 pm
the 410 mounts (on mine at least) sat lower down on the chassis than the 1.3 ones did so cut the old mounts off and welded some 1.3 ones in.
Ladaman
Post by Ladaman » Thu Mar 20, 2014 2:44 pm
I've got my old 5 speed box and a full engine available if interested.
All as removed from my Samurai.
Drop me a PM if interested.
