Not first post, but first question of my own
Just bought a Grand Vitara V6 2.5 2 weeks ago. We really love it already but I need to ask about a potential problem. The 4WD system all engages as it should using the small lever, but once in 4WD (lets stay with high range for now), the GV immediately starts pulling very strongly to the right on the steering wheel? It does the same in 4WD Low range. It also takes a little bit of reversing/forwards to get it to come back properly into 2H again. (Not much, just a bit). Our Terrano did this but then it never had this strong pulling going on and would happily drive in 4WD H mode on tarmac all day long and never felt any different to 2H apart from better grip/roadholding obviously.
Something is obviously very wrong here. I do know that even with the low mileage we do a year, (3 to 6 thousand max usually) that she will need a clutch sometime in the next 6-12 months would be my guess. Can't see a worn clutch causing this strange hard right pull though can you?
Also, while in 4WD H or L, she just feels kind of "graunchy" and there's no way she could possibly do 2H speeds smoothly etc. 2H works perfectly and is as smooth as silk. Any ideas? Front diff knackered etc maybe? Can I just use her in 2H for a long time to come lol and just ignore the front wheel drive part for now? A shame really though as I do a lot of shooting up my mates farm and with the ice and possible snow coming I will miss being able to use the full 4wd system as intended
EDIT: I should say that there are 2 brand new tyres on the front so it's nothing to do with uneven wear etc. This pull right is WAY too strong for that! Also, I forgot to say that when it's in 4WD H/L and you drive her forward there is a lot of resistance and the second you take your foot off the throttle she just comes VERY quickly to a stop almost as if you were hard braking. It sure doesn't sound too good does it?
Regards,
Andy
