dose'nt want to turn
mk1joe
Post by mk1joe » Sat Apr 03, 2010 5:57 pm
Hi
ive been trying for a while to get my car started using lots of different battries and even jumping it from another car but the starter is just not moving it fast enough. i have taken the starter out and it turns fine from a battery but the gear dosent move foreward although it dose engage when its on the engine.
any ideas?
thanks
joe
Re: dose'nt want to turn
Post by Edweird » Sat Apr 03, 2010 7:39 pm
New starter? :shock:
Feel free to pelt me with rocks.
mk1joe
Post by mk1joe » Sun Apr 04, 2010 5:20 pm
ok forgett everything i said, i took the starter motor apart and cleaned it and it started the engine for the first time :P . but the gear was very oily, is this a bad thing?
Post by Edweird » Sun Apr 04, 2010 11:05 pm
Oil on a gear can't really be a bad thing as far as a gear is concerned, as it lubricates it, but, being a gear, it won't loose traction, if you know what I mean, like a belt or tyre would. However, the starter usually turns the flywheel, and the flywheel is usually connected to the clutch, which means there may be oil around the clutch, which is not so good, as I understand it.
The question to ask is, where did the oil come from? Gearbox or Engine?
Sorry I can't be of any more help.
Goldfish
Post by Goldfish » Mon Apr 05, 2010 8:44 pm
Where did the oil come from?
Sniff it!!
Not that it makes much difference, if its from engine it'll be gearbox off, if its from gearbox it'll be gearbox off.
They call me the Goldfish..........I don't remember why!
mk1joe
Post by mk1joe » Tue Jul 06, 2010 8:02 pm
well it didnt smell horrible so i think it will be engine oil, i supose this means a new seal somewhere.
Last bumped by mk1joe on Tue Jul 06, 2010 8:02 pm.
