Turned out to be the alternator. How unlucky is that. 3 busted units.
Went to my old work, dug through a box full of alternators. Found a brand new Valeo unit running a V-belt. 70amp jobby. No idea what it's from.
Fitted up quite well. Didnt have to mod the alternator, but I did have to re-drill my alt bracket, and move it to the right by 10mm so the back of the alternator will clear the engine mount under the inlet manifold.
I then had to un-bolt the belt pulley from the alternator, and flip it over, as the off-set was wrong. It lined up more or less perfect.
It's a 1 pin / 1 terminal alternator. To whacked the battery feed onto it, and plugged the warning light wire in. Fired engine up. Instantly charging at 14.1v, which I feel is a tiny bit high. will let it run/settle, and check the voltage again tomorrow.
It's definitely juicy enough to charge 2 batteries though. Time to hunt for a winch.
Only down side, is a slight power loss under hard acceleration. Defo noticeable.
