SJ410 -1985 'Cabrio', engine rebuild
Re: SJ410 -1985 'Cabrio', engine rebuild
Ref the vac advance, I think the only way I will get a vac at WOT is to take the vac from before the carb (I.E - Out of my snorkel). Is this right? I guess the standard airbox must have had a vac hose for the dizzy?
What's the crack with fuel pressure regulator then? Is that just a regular vac from manifold? My pressure reg has 2 take offs.
Just one question. Where did you get the Suzuki ammo box?
Looks like he got an ammo box and added as Suzuki badge
Exactly that. Picked the ammo box up on a boot fair years ago, and the badge is the old one from the bonnet.
It's a handy box, as the pick up has no safe storage really, other than in the passenger footwell.
First outing in the Zook. Stuffed it in a muddy puddle, sucked a load of water in, cut out, and had to be pulled out by a Barbie Truck (Vitara). DOH!
Truck did really well other than that. Fueling is pretty crap, but I've bought all the bits for a nice snorkel now, so once that's fitted, I'll drop it in for a tune up.
Very impressed though, it's a very capable little truck. Long term, bigger tyres really will help things.
Ben
Ben
- donkeychomp
Anything without a snorkel would of cut out to be fair, unless it has about a 10" lift!
It was just the drop into the water which submerged the entire engine.
Bobb took it real easy in his Vitara though, as it's his daily. Because I've got the Transit, I like to stick the SJ through it's paces. haha
did the engine take in any water?
I think it did, but only enough to cut it out, I.E, the first splash.
I didnt try to start it again until it had been dragged right out. Gave it a flick of the keys to make sure the bores were free, then fired it up. Went after a bit of cranking, and ran boggy for a few hours until the filter dried out.
Runs perfect again now. Really need this snorkel fitted before next outing. Will also be replacing the fan with a leccy one.
https://www.facebook.com/video.php?v=4677895362995
Just bought myself a universal radiator fan. Will get that fitted up with the snorkel, bit of marine grease around the electrics, and try that bomb hole again! :p
