muddymessers build thread
Re: muddymessers build thread
Post by twiss » Thu Sep 04, 2014 12:01 pm
Have you been to see the doctor about your bent shaft and purple nuts yet?
muddymesser
Post by muddymesser » Thu Sep 04, 2014 7:27 pm
apparently its a grip issue
muddymesser
Post by muddymesser » Sat Sep 06, 2014 3:51 pm
finally got my rear tyres on at work today :smokin:
but i've noticed a problem on the front prop . . . its got a wobble on the splines as the axle has been moved forwards, ive pushed the prop together and it doesnt wobble so ive ordered an 18 mm prop spacer from bits4vits to cure that
but for now i've just removed the prop so MOT man cant say anything
i think its ready for mot on monday :guns:
muddymesser
Post by muddymesser » Mon Sep 08, 2014 6:19 pm
yay :)
passes its test today :)
failed initially on one patch of rust but he repaired it for £30 which i cant argue with :D
has afew advisory's
1, slight leak on my front hubs
2,slight play in the steering (new rag joint on its way)
3, noisy exhaust ;)
Post by twiss » Mon Sep 08, 2014 6:21 pm
yay, took you long enough ;)
muddymesser
Post by muddymesser » Mon Sep 08, 2014 6:32 pm
i know :'( i had money issues
i bought daft stuff for my sj that it didnt really need :/
like purple wheel nuts
muddymesser
Post by muddymesser » Sat Sep 13, 2014 7:46 pm
my prop shaft spacer turned up yesterday from bits4vits ;) got it fitted as soon as i got home
today driving home . . . . my rear prop thew a wobbler on me . . . uj is fudged
muddymesser
Post by muddymesser » Mon Sep 15, 2014 7:04 pm
yeah..... erm
i broke it
rear uj went so was driving it frontwheel drive . . . with FWH's off a vitara . . . with plastic internals . . . and i set off fast from work . . . BOOM . . . had to borrow a renault megan to get home :/
kiwizook
Post by kiwizook » Mon Sep 15, 2014 8:20 pm
I guess you now know to not do that again! :D
muddymesser
Post by muddymesser » Mon Sep 15, 2014 8:48 pm
nah . . . i just know to buy better free wheeling hubs before wheel spinning ;)
just found my fixed drive flanges in my tool box so i'll get those cleaned up ready to go back on at some point . . . unless some asin fwh's show up at the right price
