- The Boss
Post
by ScottieJ » Sat May 31, 2014 10:45 pm
It's worth a shot, drill it out a few sizes and us the biggest extractor that you can get away with, the bleed nipples are pretty weak so I would say you stand a good chance.
I have loads of those bolts, drop me a PM with your address and I'll post some out for you Monday.
Maybe remind me I said that tomorrow though, I'm good at forgetting
Post
by dan_2k_uk » Sun Jun 01, 2014 5:46 pm
The problem with drilling it out is if its not repairable or can't be totally removed but does break the seal then the caliper is done with.
I think I said on facebook that 3 out of my 4 are snapped off and I just bleed them through the banjos.
Bit messy but saves the effort of trying to remove it or the cost of a new caliper.
Just make sure you do it over a bucket or big container and have plenty of blue roll and brake cleaner to hand.
Post
by Tramp » Sun Jun 01, 2014 9:47 pm
Thanks I'll give it a go tbh I was looking at calipers on the internet, if I could save myself the cost of a new pair of calipers I'd be happier! Are there any tips or tricks I need to know about bleeding through the banjos? I'll PM you now Scottie, thanks!
Post
by Jordi » Tue Jun 10, 2014 8:11 pm
Get the brakes sorted?
Post
by Tramp » Tue Jun 10, 2014 9:41 pm
No, they're sat on my work bench still, I was going to have a go at bleeding them through the banjo but haven't got around to it, tbh I was thinking if the bleed nipple has failed they are probably due for replacing some point soon anyway, so I was looking at these
http://www.brakepartssuperstore.org.uk/ ... 11169.html
Mine are the Lucas type, I might get some time on it this weekend but we will see!
Post
by dan_2k_uk » Tue Jun 10, 2014 11:43 pm
Remove banjo and bolt. Fill caliper. Refit hose with bolt through banjo and screw onto caliper making sure to keep it upright and not trap any air. Nip it open and shut like a normal brake bleed with someone pumping the pedal. Give it a damn good clean before refitting the pads.
I have successfully done this about 5 times. Brakes solid as a rock.
Post
by Tramp » Sun Jun 15, 2014 12:26 pm
I bled the breaks as best I could by my self, to be honest they seemed to bleed themselves pretty well just from the pressure in the master cylinder, they work and stop now! I fitted my new 175 needle valve into my weber to stop it stalling going don hills, it was pretty straight forward apart from I lost a piece of the choke mechanism
but it's running well now and I certainly didn't drive it around the block to see how it goes, I set my weber float heights at 35mm closed to 50mm open,
- image.jpg (2.82 MiB) Viewed 5132 times
Sorted
Post
by twiss » Tue Jun 17, 2014 10:21 pm
Looking good!
I would advise a Gunson brake bleeder to anyone. Makes bleeding the brakes by yourself a piece of cake! Connects to tyre valve and uses that to provide constant pressure
None of this up down up down bollocks
My mates dad tried to bleed a fiesta hydraulic clutch with one, it was taking ages so he connected it directly to the air line and blew it up. So don't do that
Haven't tried the banjo bleeding but I imagine it will spray out everywhere haha
Rhinoman
- Suzuki Guru
Post
by Rhinoman » Tue Jun 17, 2014 10:56 pm
I've got a pressure bleeder which is a bit of a pain because you need different caps for the master cylinders, I did my Jimny at the weekend using a Mityvac clone and that was extremely simple.
I have seen banjo bolts with bleed nipples fitted, a big bike dealer used to sell them.
Edit: you can still get them:
http://www.ebay.co.uk/itm/like/37105796 ... 108&ff19=0
Post
by twiss » Tue Jun 17, 2014 11:10 pm
Might have to get some of them! Then at least if the bleeders get stuck in you can replace the whole thing
