Powertrax Lock Right done WRONG
tomread47
Post by tomread47 » Wed Jun 11, 2014 7:31 pm
hello can anyone help
i was wondering when installing a lock right do i leave the 2 small pinion shafts out and just have the large one in ?
as it is making really loud clanking noises inbetween the clicking noises they described it should do ?
thanks
tom :S:
Boyes
Re: Powertrax Lock Right done WRONG
Post by Boyes » Wed Jun 11, 2014 7:46 pm
Ask mike harris :) he runs lock rites and says there the bee's knee's!
tomread47
Post by tomread47 » Wed Jun 11, 2014 7:55 pm
how can i get hold off mike harris ?
Post by ROBBIE » Wed Jun 11, 2014 8:07 pm
He will be along sooner or later ;)
Ladaman
Post by Ladaman » Wed Jun 11, 2014 8:11 pm
Sounds very similar to when I first fitted mine. I thought a half shaft was going to snap.
I had a chat with Mike myself, pulled it in bits and sussed it out. I recall it needed 0.25mm machining off two faces of the diff carrier. Luckily my son was able to do it at work.
It's the dogs danglies now.
I will have a look at the instructions I have, and see if I can write something for you that makes sense on what to check. I recall it was a bit tricky and you need some decent engineering measuring equipment.
tomread47
Post by tomread47 » Wed Jun 11, 2014 9:54 pm
thanks ladman
get back to me about it as i dont really want to drive it as i dont want to kill my vitara
Post by mike harris » Wed Jun 11, 2014 10:09 pm
If it clicks that's fine, as long as you can hack it up and disengage it.
Make a video and send them to me.
This is why I have a professional set my diffs up as its just whitchcraft !!
tomread47
Post by tomread47 » Wed Jun 11, 2014 10:13 pm
thanks mike i video it tomorrow and try and send you it tomorrow morning
when ill see what you say when im back from work
thanks
tomread47
Post by tomread47 » Thu Jun 12, 2014 10:23 pm
i think i have sorted it now than you everyone
Ladaman
Post by Ladaman » Thu Jun 12, 2014 11:51 pm
That was easy.
What have you done?
