wiring info
neil atkins
wiring info
Post by neil atkins » Tue May 06, 2014 6:42 pm
Hi there my vitara 1992 was injection now its carberetor can someone tell me how to wire up the distributor from a carberetor model ignition module and coil in a word HELP Thanks Neil :er:
Re: wiring info
Post by Darrell » Tue May 06, 2014 8:48 pm
I would just unplug the old main relay as it's not supplying anything now and connect the b/w to ignition coil as before.
vit ign.jpg (112.31 KiB) Viewed 6389 times
neil atkins
Re: wiring info
Post by neil atkins » Wed May 07, 2014 9:01 am
Thanks darrell I have looked allmost every were I was just about to give in. It's been a long task for me to convert from injection to carberetor I hope I can get it sorted now Thanks Neil :thumbup:
Ladaman
Re: wiring info
Post by Ladaman » Wed May 07, 2014 12:13 pm
neil atkins wrote:It's been a long task for me to convert from injection to carberetor I hope I can get it sorted now Thanks Neil :thumbup:
Why would you want to do that? :er:
neil atkins
Re: wiring info
Post by neil atkins » Wed May 07, 2014 1:31 pm
Hi there I did this because the ecu nackerd on me and could not get one
neil atkins
Re: wiring info
Post by neil atkins » Sat May 10, 2014 7:56 am
Hi there thanks for the info on the wireing it works fine but lost mt rev counter what do I need to get it working Thanks Neil
Re: wiring info
Post by Darrell » Sat May 10, 2014 11:05 am
Hopefully there is still the old brown with white tracer coming from the main wiring loom that went to the old coil. It came from the noise suppressor which I hope is still there, if so connect this to the coil negative terminal and see if that works.
vit inj ign.png (73.94 KiB) Viewed 6328 times
neil atkins
Re: wiring info
Post by neil atkins » Sun May 11, 2014 12:55 pm
Thanks again Darrell put the wire on and the rev counter works Thanks Neil :doublethumbs:
Rhinoman
Re: wiring info
Post by Rhinoman » Sun May 11, 2014 7:46 pm
neil atkins wrote:Hi there I did this because the ecu nackerd on me and could not get one
You could have spoken to me I do repairs and have exchange units.
