Merc Drop Pitman with Jimny PS box?
Cyprus Geoff
Post by Cyprus Geoff » Sun Mar 30, 2014 10:45 am
Hi people!
I have Jimny power steering fitted to my Samurai. I am about (FINALLY - shut up Kibris :D ) about to fit YJ springs which will give me 2 -2.5" of lift.
a) will I need to do any steering mods?
b) if I need to use a drop pitman arm off a Merc, will it fit my Jimny PS bos or will it only fit a Vit PS box?
Thanks,
Geoff
Re: Merc Drop Pitman with Jimny PS box?
Post by ScottieJ » Sun Mar 30, 2014 4:55 pm
If running YJs spua then you should be fine with the standard steering set up, YJs only usually lift around 1.5-2" I run standard steering on mine.
Never heard of people using pitman arms off merc boxes? Not getting confused with the merc half hi-steer conversion are you?
kibris
Post by kibris » Mon Mar 31, 2014 11:14 am
Cyprus Geoff wrote:Hi people!
Thanks,
Geoff
:smokin:
Cyprus Geoff
Post by Cyprus Geoff » Tue Apr 01, 2014 11:14 am
Yup! You are correct Scottie :oops: :oops:
Mark........... :thefinger: :thefinger:
