Overheating
Re: Overheating
Post by ScottieJ » Mon Mar 10, 2014 1:39 pm
Maybe for the time being whip the existing thermostat out and run it without one fitted, it's good for a short term solution but I would never advise running without a thermostat for long.
Providing that it is just the thermostat that is the issue it should stop the overheating and reduce the chance of blowing the head gasket from overheating. If however without the thermostat fitted it still over heats then there is another problem.
Sj410red
Re: Overheating
Post by Sj410red » Mon Mar 10, 2014 9:12 pm
I reckon it's the stat, so hopefully an easy fix. There's a paper gasket on the stat housing, undo bolts and prise housing off carefully and you may be able to re-use the gasket, new stats don't always come with new gaskets. Failing that get some gasket paper and make one, I had to do that for my fuel pump gasket.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
sharon
Re: Overheating
Post by sharon » Mon Mar 10, 2014 9:53 pm
Have found gasgets on eBay also, hopefuly should all be sorted by the weekend, failing this I shall be back on here :-)
sharon
Re: Overheating
Post by sharon » Mon Mar 17, 2014 12:52 pm
Hi, have put on a new thermostat and replaced gasget at the weekend, flushed it and refilled it, drove about 25 miles mostly motorway at a steady 60 all the way and all again the water is all gone from radiator and overflow reservoir ??? Any ideas what to try next please. Thanks.
Re: Overheating
Post by twiss » Mon Mar 17, 2014 12:58 pm
What temperature did it get up to? Have you replaced the rad cap as well?
sharon
Re: Overheating
Post by sharon » Mon Mar 17, 2014 1:05 pm
Just over the halfway point on the temperature gauge and no haven't changed rad cap
Re: Overheating
Post by twiss » Mon Mar 17, 2014 1:48 pm
it might be stuck with all the gunk in it, allowing your radiator water to heat up and escape into the expansion tank as steam... but thats a hell of a lot of water to be losing over 25 miles!
worth replacing though as they are only like £5
sharon
Re: Overheating
Post by sharon » Mon Mar 17, 2014 1:54 pm
Will get one ordered........watch this space !!
Re: Overheating
Post by ScottieJ » Mon Mar 17, 2014 2:45 pm
I would check for a possible headgasket failure as well.
Get a compression and sniffer test done.
I wonder if it has the wrong temp sender for the temp gauge fitted so it's showing the wrong temp but actually overheating.
sharon
Re: Overheating
Post by sharon » Mon Mar 17, 2014 2:54 pm
Will try all of the above, how do I know if its got the wrong temp sender on it ?
