sj 410 burning oil
- bencotterell
sj 410 burning oil
Ok so my sj410 is burning alot of oil going to replace the valve stem seals found set on ebay with head gasket kit when i strip the engine down any thing else there worth doing/changing?
- timwilks13
- SCUK Website Padawan
Re: sj 410 burning oil
personally i would do i full top end gasket change, may not be part of the issue but for the price it cant hurt, then you know its done ey
- bencotterell
I found full head gasket kit on ebay so will do all of the gaskets i get in the set is it worth doing piston rings cam belt and water pump while in at it?
Just watch out for the piston rings on ebay, they are not of the best quality from my experience.
- bencotterell
Ok so in found out today that the sj not burning as much oil as 1st thought i got oil leak aswell. Will fix oil leak first and gi from there. Any one no what size copper washer i need for sump plug.
I've never replaced a sump plug washer in my life!
- bencotterell
So the oil leak turned out to be my own fault didn't do sump plug up tight 1 oil leak done now to sort transfer box out.
- dazerede
My 410 burns oil like mad there is no leaks and I have put about 8 litres of oil in my Sj since it's been on the road which is 10 months I'm not to bothered as there will be a 1.6 conversion this year or next year
4” calmini lift kit
4” calmini lift kit
![:) :)](./images/smilies/icon_e_smile.gif)
- bencotterell
I wanted to do a 1.6 conversion but at the min just want to get it running right and stop oil leaks the transfer box is the next on my list of jobs to do. Maybe engine conversion next year.
