Master Vac
rebecca
Master Vac
Post by rebecca » Mon Mar 03, 2014 3:27 pm
Hello there,
I have a Suzuki vitara TD 1997.
I've been told that the master vac needs replacing.I can't find the exact model anywhere.
Can I use a master vac for a santana samurai???
Help-I'm totallt lost!!!!
Re: Master Vac
Post by Darrell » Mon Mar 03, 2014 8:39 pm
I assume they mean the vacuum pump needs replacing :er:
The one for the "Santana Samurai SJ419" is the same part number as for the Vitara SE419
Hope this is what your after, they aren't cheap :cry:
se419 diesel vacuum pump.jpeg (281.58 KiB) Viewed 4799 times
fatdaz
Re: Master Vac
Post by fatdaz » Tue Mar 04, 2014 12:35 pm
i picked one up yesterday from my local scrappy for £20 :)
came off a peugot 205 diesel!
2 samurais. 1 vit and now a vit commercial :)
Re: Master Vac
Post by Darrell » Tue Mar 04, 2014 9:53 pm
They are fitted to quite a few different diesel vehicles.
I have noticed that the inlet/outlet pipe direction does alter though.
I would expect the cap to screw on whichever direction required but don't know for sure.
721114500-PIERBURG-721114500-Vacuum-Pump-brake-system-for-CITROEN-FORD-PEUGEOT-SUZUKI-.jpg
721114500-PIERBURG-721114500-Vacuum-Pump-brake-system-for-CITROEN-FORD-PEUGEOT-SUZUKI-.jpg (300.03 KiB) Viewed 4772 times
