I don't understand why only one side indicators works
I thought the fuse had gone , so no indicators would work or the reverse lights as they share a fuse.
Hazards however have there own fuse. As these work it seems they are wired correctly.
Indicator relay knackered hence indicators not working plus we traced the reverse lights wire back to a connector in the engine bay and it seems there should be a cable plugged into it then going to the connector on top of the gear box........can anyone point me in the right direction of what it is I need, (does it have a part name/number for instance), or any drawings I can find it on, better still does anyone have one for sale. cheers.
