Inclinometer my way
Inclinometer my way
Post by andyrew » Sat Feb 08, 2014 10:17 pm
Many moons ago the little door on the dash of my jap sami
Fell off. But I struggled to find a good one to replace it.
(Spanish sami ones are a shinny finish and it would bug me)
Ive had a empty hole with just crappy change and rubbish.
At wagtail I got showered in 5p coins and other irritatingly small things
when I hoofed up a small But steep incline.
I like the factory inclinometer but there's no way im paying
The prices they go for!
So after the brutal attack my aftermarket inclo did to me
I ripped it to bits! And decided to start making a better version
Re: Inclinometer my way
Post by donkeychomp » Sat Feb 08, 2014 10:56 pm
Nice work as usual matey. I need to get one of those!
muddymesser
Post by muddymesser » Sat Feb 08, 2014 10:59 pm
looks good . . . will be interesting to see if it site level when its in
Post by andyrew » Sat Feb 08, 2014 11:03 pm
muddymesser wrote:looks good . . . will be interesting to see if it site level when its in
I thought this too but its basically two gears and a weight.
So I just disengaged the gears and repositioned the weight
Now the dial reads level :thumbup:
Post by Tramp » Sat Feb 08, 2014 11:33 pm
I'm impressed and looking forward to see it fitted, I've wanted one for ages and this might be a lot better than a standard one! Or at least cheaper!
Post by twiss » Sat Feb 08, 2014 11:37 pm
looks good man! I think I might rethink my dash Idea and put a phone in that slot... go back to the standard temp gauge and replace the cluster with a working one!
if i can do it anywhere near as tidy as that I'll be impressed ;)
Post by andyrew » Sat Feb 08, 2014 11:42 pm
Next step is a bit overkill but im a bit of a factory look
Person. I noticed that the old door is not completely
Flat so ive cut the door in half and stuck the two pieces
And the new frame down on a flat surface and skimmed
Over with filler to match the radius of the panel around the clock
Ill get some photos when ive finished the prep
Post by Tramp » Sun Apr 06, 2014 8:09 am
:poke: Any updates on this?
jim tylee
Post by jim tylee » Sat May 03, 2014 1:41 pm
When i bought mine it already had this installed on the dashboard.....these were on ebay for about 12 pounds each seems to work quite well, also the unit on its right which is a rev limiter come resettable audio warning that one can set the rpm to
jim tylee
Post by jim tylee » Sat May 03, 2014 1:42 pm
Sorry rev limiter not in the picture
jim
