earthing problem
maker
earthing problem
Post by maker » Wed Feb 05, 2014 10:42 am
Ive got a earth from the starter to battery but not to the body? Should there be one? As some times its like the battery is flat but then it will start after a couple of turns of the key! Thanks dave
ferris
Re: earthing problem
Post by ferris » Wed Feb 05, 2014 10:59 am
Yeah there should be a earth wire connected to the body right next to the battery.
maker
Post by maker » Wed Feb 05, 2014 11:32 am
From the starter or battery?
ferris
Post by ferris » Wed Feb 05, 2014 11:34 am
From the battery.
Ladaman
Post by Ladaman » Wed Feb 05, 2014 12:07 pm
Isnt it live (+) from battery to starter.
negative (-) from engine to body & body to battery?
ferris
Post by ferris » Wed Feb 05, 2014 3:57 pm
There is also a big 16 mm neutral that go's from the battery to one of the bolts that holds the starter to the gear box.
