Which Battery?
Re: Which Battery?
Post by Anton » Mon Jan 20, 2014 4:30 pm
Scouse Lee wrote:Cheers guys, plenty for me to think about there.......the battery I've got on is a Drive Tec Heavy Duty Part Number 085, 330 cold cranking & 40 Ah, (not that it means anything to me :er: ). I've just put it back on and started the old girl, took a bit but got there in the end so I'm not sure if this batteries ok or not really I'll just have to keep my eye on it, would still like a new one though.
The web tells me that the "standard" battery for a vit does 300 cold cranking amps and 36Ah.
Anything over and above this is fine, although probably not worth paying extra for unless you have loads of accessories/lights/winches/fairydustguns.
Scouse Lee
Re: Which Battery?
Post by Scouse Lee » Mon Jan 20, 2014 4:51 pm
[quote="Anton"
Anything over and above this is fine, although probably not worth paying extra for unless you have loads of accessories/lights/winches/fairydustguns.[/quote]
I've got 3 spots/cb/winch........my fairydustgun is broken :guns:
Re: Which Battery?
Post by Anton » Mon Jan 20, 2014 5:54 pm
Don't bother with the winch with that battery. The rest should be ok.
For a winch, you probably want in excess of 200Ah.
