Twiss' supercharger+EFI
NylonAdmiral
Re: Twiss' supercharger+EFI
Post by NylonAdmiral » Thu Jan 16, 2014 7:02 pm
Only just picked up on this thread, it looks awesome!
Post by twiss » Thu Jan 16, 2014 8:40 pm
OK so mine is a late model vit with an early model hot wire MAF sensor with built in IAT sensor
You can see the IAT sensor inside the MAF sensor pipe.... duh!
I haven't got the immoboliser model number on me but will check it on my next trip out to the garage
I have the MAF and TPS connectors from section 6E1-3 of the later immobiser manual...
Can you tell me how these relate to vref, signal, and ground (for the TPS) and any idea what B+ and Is connect to? I'm guessing one is temp and one is MAF?
Rhinoman
Post by Rhinoman » Thu Jan 16, 2014 8:44 pm
MAF:
B+ is battery
Is is signal
TPS:
Vc = 5V
Vs = output volts
Id = idle
E2 = gnd
Post by twiss » Thu Jan 16, 2014 11:18 pm
OK so I guess no temp sender... last place to look is the lower airbox which I think is in the back of the truck...
I will get it and check it out but I'm not so sure there is one on there... Im going to leave the MAF sensor disconnected for now but might use it later on
I'll fid the immo as well
Post by twiss » Fri Jan 17, 2014 12:59 am
NylonAdmiral wrote:Only just picked up on this thread, it looks awesome!
Cheers man hopefully I will be able to get it going ;)
Your truck looks awesome by the way, hope I get to see it next time I'm over wiltshire way!
Post by twiss » Fri Jan 17, 2014 4:16 pm
Right I've now made a blanking plate for the EGR stepper motor... all of the solenoids and pipes for it are now gone! Should still be able to pass emissions as I've only got to meet carb targets...
Rhinoman, do you have any info about the stepper motors? I'm wondering if I can make a mini manifold for it and use it for IAC...
also the tiny solenoids that the EGR system uses... do you know if they can take 12v or just 5v?
I might use one in the air line to the MAP sensor... then I can have a hidden switch which will open and close the solenoid and stop the engine from running!
I will give the PWM valve a go though to begin with...
Rhinoman
Post by Rhinoman » Fri Jan 17, 2014 4:28 pm
The stepper motor info is in the link above, on my engine there are no other solenoids on the EGR. You should have one for canister purge and maybe on for the throttle opener if you have one, those are 12V.
Post by twiss » Fri Jan 17, 2014 4:41 pm
Yeah its the canister purge one I was looking at... should default closed I guess so I can wire it into the ignition via a switch... so if the switch is off it won't start!
Cheers, I'll check out the stepper info as the holes in it look about the same size as the pipes coming out of the standard idle valve!
Post by twiss » Sat Feb 08, 2014 3:27 pm
Rhinoman,
I think I saw you posted about looking for a crank position sensor for a jimny... just wondering on the offchance... do you know if they (or any other zook CP sensors) fit on a vit 16v engine?
Rhinoman
Post by Rhinoman » Sat Feb 08, 2014 3:39 pm
I'm looking for the trigger wheel from the camshaft, I'll probably end up making my own. The later cam sensors would need a different cam because they are driven off the end rather than from gears. If you change the cam then the optical sensors are the most versatile because they are easily modified to create different patterns.
