1.6 16v wiring harness
wots the best way of stripping harness to just all wires for engine operation to ecu cheers chaps
Re: 1.6 16v wiring harness
bloody wires everywhere not sure best way of doing it.
Follow the link I left you in the question you asked in the electrical section it leads to a very comprehensive write-up which goes into massive detail and makes the loom job very easy id say I did mine in about 2 hours by just using the ecu pin out diagrams.
I've got this to look forward to sometime in the next few weeks can't wait to get rid of the SU!!!!
well spaghetti junction here i come !!!! cheers chaps i'll give it a stab lol .
It aint as bad as it looks just follow the diagram from ecu pin location to each plug along the correct wire colour, remove what you dont need cutting wires most of the times at spliced junctions and removing the pin from the relevant plug using a small screwdriver. Before I started I labelled each plug so that when taping the loom back up I knew what needed to tee off where. A few supplies need to be put in and the fuel pump supply extending. I did the power upgrade using the main fuses from the vit to do away with the sj fuse wire. You will end up with about 30%-40% of the original loom left after modifications. If you need any help fire away il do my best
cheers pal u been a real help this sites got some nice characters on it .
