fitting engine
ikuzusdink
fitting engine
Post by ikuzusdink » Mon Dec 30, 2013 11:02 pm
i guess when fitting engines in these zooks its easier to take wings n front end of so u just got chassis to bolt straight on to i guess :er:
Re: fitting engine
Post by donkeychomp » Mon Dec 30, 2013 11:05 pm
Wouldn't bother personally.
Re: fitting engine
Post by Jordi » Mon Dec 30, 2013 11:07 pm
Can be easier to remove the whole front end as one lump, depends how rusted on they are.
Ladaman
Re: fitting engine
Post by Ladaman » Mon Dec 30, 2013 11:13 pm
I suppose it depends on what lifting tackle you have available too, and how high your truck is. :lol:
ikuzusdink
Re: fitting engine
Post by ikuzusdink » Mon Dec 30, 2013 11:24 pm
cheers chaps like ive been told alot of wiring on a 1.6 16v engine but im sure i will conquer it hopefully lol mind got all winter ive got loom n ecu so will have to play n see wot wud ure preference be??
Re: fitting engine
Post by Jordi » Mon Dec 30, 2013 11:26 pm
ikuzusdink wrote:cheers chaps like ive been told alot of wiring on a 1.6 16v engine but im sure i will conquer it hopefully lol mind got all winter ive got loom n ecu so will have to play n see wot wud ure preference be??
If you like wiring check out Ladamans build / engine swap.
Jay18
Re: fitting engine
Post by Jay18 » Mon Dec 30, 2013 11:27 pm
if i had a 1.6 16v with loom and ecu id give it a go, more power and torque than the 8v, aslong as you dont plan on drowning your zuk youll be fine :)
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
ikuzusdink
Re: fitting engine
Post by ikuzusdink » Tue Dec 31, 2013 12:10 am
thanks chaps .
Re: fitting engine
Post by mike harris » Tue Dec 31, 2013 7:33 am
The wiring is easy !! Here's a picture of when I was doing mine :)
ikuzusdink
Re: fitting engine
Post by ikuzusdink » Thu Jan 02, 2014 7:31 pm
i guess u had to strip ure loom down then ? bloody wires .
