king pin bearings have gone in my 410 axle
dazerede
Re: king pin bearings have gone in my 410 axle
Post by dazerede » Mon Dec 09, 2013 11:57 pm
Ummmm ideal Darrel
4” calmini lift kit :)
Post by Darrell » Tue Dec 10, 2013 12:02 am
dazerede wrote:Kingpins bearings have gone :cry:
Vidoe of how bad it is lol
http://www.youtube.com/watch?v=0V-sOiHe ... ata_player
Not quite my normal diagram -- :D
Post by Edweird » Tue Dec 10, 2013 12:12 am
That's a dynamic camber system. Fancy stuff.
Post by dan_2k_uk » Tue Dec 10, 2013 6:46 am
Darrell wrote:I believe both use 30302
15mm x 42mm x 14.25mm taper bearing
I swear in a guide I read on Jimny death wobble it said they differ. Maybe its just the shimming that is different as I know on a Jimny you shim the pin head to add pressure to the bearings rather than shimmimg the pin mount to reduce it.
Post by dan_2k_uk » Tue Dec 10, 2013 7:56 am
Sorry. Both use a 30302j. Just the shimming setup is different.
dazerede
Post by dazerede » Tue Dec 10, 2013 9:40 am
Ok chears guys
Post by ScottieJ » Tue Dec 10, 2013 10:01 am
That's so bad I wouldn't be surprised if you've actually snapped a kingpin! If so I have a hoard of spare kingpins :thumbup:
dazerede
Post by dazerede » Wed Dec 11, 2013 7:48 pm
Write I had a day off college so I took it all apart and found that the kingpins are in good condition it was just the bearings that have gone so that saved me a couple of quid I think I have a set in.the shed as I have a spare front axle in.my shed apart from the casing parts are ordered and should be here tmoz from jimnybits
Post by ScottieJ » Wed Dec 11, 2013 8:50 pm
Don't think I have ever seen such fucked kingpin bearings :shock:
steve greenc3
Post by steve greenc3 » Wed Dec 11, 2013 8:57 pm
Have you a bit broken out of bearing cup in axle? I managed to wipe out half the cup on mine, so had to change axle.
