arches
timwilks13
SCUK Website Padawan
arches
Post by timwilks13 » Tue Nov 26, 2013 2:42 pm
Getting on with my arches whilst I wait for engine bits to arrive, but how have people done theirs with just metal? I'm planning on just using a strip of metal sticking out an inch or so so I can attach rubber to the lip, but should I have the strip sitting on the top of the arch inside the wing or underneath the arch? Is there a 'right or wrong' way or is it personal preference?
Re: arches
Post by dan_2k_uk » Tue Nov 26, 2013 2:55 pm
Anything you want really. Mine is just butted up to it as it means its easier to shape the old inner arch to meet it and put relief slits in if you end up with excess material at some point.
Re: arches
Post by Jordi » Tue Nov 26, 2013 3:34 pm
Use a joggler and overlap it on the top and seam weld the underside.
timwilks13
Re: arches
Post by timwilks13 » Tue Nov 26, 2013 3:49 pm
Jordi wrote:Use a joggler and overlap it on the top and seam weld the underside.
Joggler....?
Re: arches
Post by Edweird » Tue Nov 26, 2013 4:17 pm
Re: arches
Post by ScottieJ » Tue Nov 26, 2013 4:27 pm
Are we talking virtual lift here or just arch repair?
timwilks13
Re: arches
Post by timwilks13 » Tue Nov 26, 2013 4:36 pm
ScottieJ wrote:Are we talking virtual lift here or just arch repair?
Virtual lift, taking the arches to the inner arch height.
kiwizook
Re: arches
Post by kiwizook » Tue Nov 26, 2013 6:27 pm
you can just overlap the two pieces of metal. and weld them an inch, and then leave an inch, and do the oposite on the underside if you know what i mean. this will create a zipper weld, and it is very strong. when you are done, just fully seam seal both sides, and it will last a very long time. this way it is easier then just butting up, and also stronger
Re: arches
Post by ScottieJ » Tue Nov 26, 2013 6:46 pm
No point doing more than a butt weld on bodywork in my opinion, also means less welding and nowhere for moisture to sit like there is with overlapped repairs.
Nowadays I prefer to remove the original arch lip and re-attach it after the virtual lift so you can fit the original arches, then just add spats for extra width etc.
Re: arches
Post by mike harris » Tue Nov 26, 2013 6:52 pm
Just take some of a samurai?
Mike :)
