The " Goat Chaser"
- turbo-tom
Re: The " Goat Chaser"
well your certainly not boring me with it! , if you up to it im sure you would be aloud to bang up another build thread for it in the general build section!
Tom
Ford Fiesta ST
Ford Fiesta ST
You bore me mate! im around them constantly and I cant get enough of them.
1994 Pick Up Converted Vitara
+2" Springs, Pro Comp Front And Rear Shocks, 31" Marshalls On 8j's, Front Winch Bumper, OMP Steering Wheel And Boss, Bucket Seats, Stripped Out, Black Bonnet With Scoop, Few Dents And Scratches, Little Rust!!!
Sorry no more escort bit in this thread then.rory-ray wrote:You bore me mate! im around them constantly and I cant get enough of them.
Today I crimped new terminals on the eBay Indicators, changed a couple of dead bulbs and tried to get the car as ready for an Mot as I could. Dad washed and hovered the car out while I got on with welded bits on the escort.
Took the car for a drive around the fields and over the massive mount of straw and horse muck from the stables.
Only photo of the SJ I took.
Well I drove the SJ and the brakes pulled, so I took the rear drums off to fine a seized right rear wheel cylinder. And the rear shoes are fairly worn. So a bit more to do before it goes for a Mot.
Dependant on what you're intending on doing with the SJ i would recommend carrying out a rear disc conversion, I found rear shoes & cylinders wasn't cheap (£60 with garage discount!)Matt King wrote:Well I drove the SJ and the brakes pulled, so I took the rear drums off to fine a seized right rear wheel cylinder. And the rear shoes are fairly worn. So a bit more to do before it goes for a Mot.
Rear discs don't require continual adjustment if you go through mud/water.
Well surprisingly it went through an Mot this morning. Now I will start tidying the thing up.
It needs a steering damper as its more like sailing than driving at the moment.
Thinking I might tub the arches so I can put the axle back underneath.
At least it will be usable for the snow!
- timwilks13
- SCUK Website Padawan
good job on the MOT
! just in time for the 'supposedly' worse winter in 60 years!
Matt King wrote:Well surprisingly it went through an Mot this morning.
Not jealous, not jealous, not jealous, not jealous...
Don't kid yourself Anton
twiss wrote:Don't kid yourself Anton
