Sj410 bogging when revved ,
Chris_38
Post by Chris_38 » Tue Nov 12, 2013 2:57 pm
Hi I've tyred researching on this all day I start the sj choke on after 5mins or so it will idle with out it then I goto rev an it wants to die , pure bogs down like its gettin no air , so I ripped the air box off tyred again an it stil j's goes daahhhh dahhhhh an don't rev , I've tyred cleaning the distributor an hav a slight improve ment but I generally. Think it's down to mixture , I've bought it like this an am jus starting to learn about them
Chris_38
Re: Sj410 bogging when revved ,
Post by Chris_38 » Tue Nov 12, 2013 3:02 pm
I carnt upload an imagine I don't kno why ]
timwilks13
SCUK Website Padawan
Post by timwilks13 » Tue Nov 12, 2013 3:15 pm
welcome to the club! It does sound like a mixture issue if its starting and idling, but stalling when being revved. If its still doing it with the air box off check your fuel lines aren't block and the pumps working and have a fiddle with the needle, i have found its quite hard to make things worse so just have a play around, good way to learn!
ferris
Post by ferris » Tue Nov 12, 2013 6:06 pm
I would also check the dizzy cap, rotor arm, and ht leads. A coked up rotor arm or a dodgy ht lead could be causing it to missfire under load.
Post by ScottieJ » Tue Nov 12, 2013 7:07 pm
Does it rev up ok with the choke out?
Personally I would give the carb a strip and clean, then give the ignition system a good check over.
Check the points in the dizzy, the contact surface should be clean and smooth and the gap should be set to .4 to .5mm
New points and a condensor are always a good things to fit when you get a 410 as they are cheap and you never know how old the ones fitted are.
Where in the country are you? Might be a member local to you who'll be willing to pop over for a look.
juncopartner
Post by juncopartner » Wed Nov 13, 2013 10:00 pm
Has this just happened in the recent cold weather?
It may be as simple as your air box is still set on summer or more likely the aluminium duct that draws hot air of the exhaust is split/missing and as a consequence is pulling cold air into the carb and "icing" the fuel. I would check that before doing anything else. 410's will not run in winter without the hot air. To be honest 410 carbs are very reliable, never had trouble with one yet, apart from the icing problem which is not the fault of the carb. LJ carbs are even worse and very unreliable, which is why I used to fit SJ carbs to my LJ,s.
