Front Axle Seals/Wheel & Kingpin Bearings Guide Needed
Scouse Lee
Post by Scouse Lee » Tue Nov 05, 2013 2:28 pm
Hey up, well I've got my seals/bearing kit for the front axle on my SJ413 and intend to start it tomorrow, problem is I'm sure I saw a step by step guide on here somewhere but can only find one for the Kingpin bearings.........can anyone help before I make a mess of things :er:
Re: Front Axle Seals/Wheel & Kingpin Bearings Guide Needed
Post by twiss » Tue Nov 05, 2013 3:53 pm
Hi,
Here's the front wheel bearing guide:
http://www.suzukiclubuk.co.uk/diy/18-wh ... l-bearings
As for the seals, you have to take them off to get the kingpin bearings out...
Take the shafts all the way out and then you won't have to cut the oil seals to get them in :)
Post by turbo-tom » Tue Nov 05, 2013 5:14 pm
There was a guide on dufflick somewhere.
Post by ScottieJ » Tue Nov 05, 2013 5:17 pm
turbo-tom wrote:There was a guide on dufflick somewhere.
Stop swearing you :homo:
Post by twiss » Tue Nov 05, 2013 5:20 pm
hahah yes don't mention the d word ;)
Post by turbo-tom » Tue Nov 05, 2013 6:12 pm
Off to that naughty step again. Sorry Dad. :roll:
kiwizook
Post by kiwizook » Tue Nov 05, 2013 6:27 pm
:hahaha: :hahaha:
Scouse Lee
Post by Scouse Lee » Thu Nov 07, 2013 6:51 pm
Cheers guys, well I've got the wheel bearing/king pin bearing guides sorted but need to go further back now to replace oil seals/steering knuckle seals etc.......... I've removed manual hubs/wheel bearings/brake discs/backing plates now, (one side had no circlip and all wheel bearing locknuts were only finger tight!), btw I need to look for a box spanner to remove/tighten the locknuts, what size are they. I have one for a Hilux but that is 50mm, I presume the ones on the SJ are about 46mm?, (not checked yet).
Post by Anton » Thu Nov 07, 2013 9:37 pm
Hilux is 54mm, SJ is 50mm.
Scouse Lee
Post by Scouse Lee » Thu Nov 07, 2013 9:47 pm
Anton wrote:Hilux is 54mm, SJ is 50mm.
Cheers Anton :thumbup:
