Oops, gear stick misshap
ianedwards
Post by ianedwards » Sun Nov 03, 2013 8:01 pm
:er:
Bit stumped about this. I took the gearstick out for a bit more space, popped it back in and now it won't select. Seems jammed and will only push over to the right, rocked the truck and it is in a gear. All I can think of is I some how put it in gear when I took it out but I'm sure it was in neutral.
Didn't get much time to look at it, plus I couldn't find a torch.
Any on got any ideas before I tackle it again.
Cheers.
Ian
Ian. :)
Re: Oops, gear stick misshap
Post by ScottieJ » Sun Nov 03, 2013 8:11 pm
Pull the lever out and look at the selectors,should all be lined up if it's in neutral. probably got knocked in gear, just line the selectors up with a screwdriver and pop the lever back in, or you can try and put the lever back in with it in the position of whatever gear it's in? I usually just do it with a screwdriver though.
ianedwards
Post by ianedwards » Sun Nov 03, 2013 8:14 pm
Yea thought as much :S . Will have to have a go when I can find a torch.
Cheers.
Ian. :)
Post by andyrew » Sun Nov 03, 2013 8:40 pm
Jordi was around for my last gearstick miss hap
Scars starting to fade now :lol:
Post by dan_2k_uk » Sun Nov 03, 2013 8:57 pm
I got done over by this too.
Line all three grooves up in the center position and pop the lever back in.
ianedwards
Post by ianedwards » Sun Nov 03, 2013 11:17 pm
Glad I'm not the only one.
Ian. :)
Post by Jordi » Mon Nov 04, 2013 2:17 am
andyrew wrote:Jordi was around for my last gearstick miss hap
:hahaha: :hahaha: :hahaha:
Post by twiss » Mon Nov 04, 2013 9:11 am
We've all been there :)
The annoying bit is being stuck in reverse as you have to lever up the flap and then move the selector underneath it :roll:
