- The Boss
Post
by ScottieJ » Mon Jul 21, 2008 1:14 pm
Simon
Post
by Simon » Mon Jul 21, 2008 2:14 pm
Yeah once you have put the new bearing and collar on, put some PU7 around the end of the collar to glue it on
a bit of PU7 makes all the difference, it will help stop the collar from coming off
- The Boss
Post
by ScottieJ » Tue Jul 22, 2008 12:08 pm
Cool i'll try that! funny how they're called locking collars and they don't seem to lock very well
Post
by dan_2k_uk » Tue Jul 22, 2008 6:40 pm
ha ha ha ha. How the eff did u do that? More to the point how did u get it home?
- The Boss
Post
by ScottieJ » Wed Jul 23, 2008 12:12 pm
well i tried to get the bearing and collar out of the axle to put it all back together but it didn't want to cooperate so i ended up just hammering the shaft back into the axle, it was pretty much just the tightness on the bearing holding it in
then i just hoped that it would get me home, it was a very slow 30MPH, 25 mile drive but the shaft actually stayed in all the way! in fact the bearing was still solidly on the shaft when i got home and stripped it all back down again!
baRoN
Post
by baRoN » Thu Jul 24, 2008 1:52 pm
That looks an inconvenient place for your axle to disassemble itself. Good that you had a hydraulic jack with you, but it looks like that farm (hi-lift) jack is left with its handle in gonad popping mode!
With the handle left back the weight of the vehicle can push the jack back down, cranking the handle up and down with bone cracking organ rupturing ferocity.
That sort of mid-mud vehicle disintegration makes breaking down by side of the road in the rain seem like luxury. Well done for making it home at all... even at 30mph.
- The Boss
Post
by ScottieJ » Thu Jul 24, 2008 5:01 pm
yeah luckily my mate had a trolley jack on him! I was only using the hi lift to get the trolley jack under the axle as its a bit safer on a trolley jack
Post
by Tramp » Sat Jul 26, 2008 1:01 am
but it looks like that farm (hi-lift) jack is left with its handle in gonad popping mode! With the handle left back the weight of the vehicle can push the jack back down, cranking the handle up and down with bone cracking organ rupturing ferocity.
ha i know what you mean, mine has done that a few times, and with a bits4vits handle holder it acts as a perfect cushion for the handle at the top of the stroke,
Luke
urbanzook
- Winching along now
Post
by urbanzook » Sun Jul 27, 2008 8:06 pm
my driver side rear wheel started making a funny clicking sound the other day, and after seein this happen to you.
i stopped driving an had a look there was 4 or 5 stones in the tread so i flicked them out with a screw driver an jumped back in an started to drive. it was still there so i stopped again and got out scratched me head an gave the wheel a good wiggle to see if it was loose or something. to my horror it squeaked an clicked, thinking my 4/5 month old bearings were shot i drove home very slowly waching my wheel thinking it was going to come off an ova take me with the shaft still on it.
got home jacked it up an stripped it down every thing was ok could not find any thing wrong till i went to put the wheel back on an there was 3 small stones on the inside of my centre cap where they came from i dont no but i have a very helpful little girl so maybe there's my answer. any way all back together an fine no noises.
just wanted to share
