Throttle Sensor set up
Craven
Re: Throttle Sensor set up
Post by Craven » Sat Oct 19, 2013 8:54 am
Sorry should of put that , I'm in Wakefield West Yorkshire if anyone can help
Rhinoman
Post by Rhinoman » Sat Oct 19, 2013 5:32 pm
Too far from me sorry. Are you sure that the cat isn't blocked?
Craven
Post by Craven » Sat Oct 19, 2013 7:07 pm
No worries, Vitara Mad has said to check the cat first................. Sooooooooooo I was meant to be in for the retest this morning but as I had the engine problem once i fitted the cat I had to cancel it. Decided to do some other little jobs as I was fed up with trying to solve the running problem, I got touching se paint up in the engine bay and noticed the maf sensor lead was not pluged in!!!!!!!!!!!!! Pluged it in, turned the key and yep it worked bloody fine! The fault light still comes on but when you rev the engine it goes off till it ticks over again. What dumb ass lol
Least its running ok for now, just need to find out why the light is still coming on, the code is still showing TPS but least its running.
Rhinoman
Post by Rhinoman » Sat Oct 19, 2013 7:28 pm
Check the TPS voltage while slowly increasing the throttle position, if you have any dead spots then its shot.
Craven
Post by Craven » Mon Oct 21, 2013 7:52 am
Ta I'm guna have another look tonight to see if I can understand it!
