starter motor problem
Re: starter motor problem
Post by twiss » Mon Oct 07, 2013 12:49 pm
Mine was having such a job drawing power to the solenoid that the ignition barrel internals have now melted! So now the ACC terminal is internally connected to the starter terminal!
Time for a starter button I think!
Post by turbo-tom » Mon Oct 07, 2013 10:02 pm
twiss wrote:Time for a starter button I think!
Remember to get a decent one ive got a graystone one now and thats really good! :D
Post by twiss » Tue Oct 08, 2013 9:17 am
Yeah don't really need that much of a decent one as its only powering up a relay now...
Post by Anton » Wed Oct 09, 2013 12:17 am
I've seen this exact problem with a Lada Niva. Basically Twiss's right (if your problem is the same thing) - with the Niva, basically the cable that carries power to the starter just got frayed internally over time and lost it's ability to carry a decent current - the starter couldn't pull enough amps from a perfectly decent battery, and acted like it wasn't getting power.
The solenoid, only needing a fraction of the power, engaged just fine.
We ran a new cable and it worked just fine.
So try running a separate cable directly from the battery to terminal A on Darrel's diagram, turn the key and see if the problem goes away. If it does, replace the cable that goes to A, or run a new one through a relay as everyone's suggesting. Don't forget to add an inline fuse to the new cable though, it's a real fire hazard to have something unfused connected directly to your battery!
If it doesn't, that means something in your starter (between A and C) is b0rked. Open up your starter and look for damage.
ScottDabinett
Post by ScottDabinett » Wed Oct 09, 2013 10:21 pm
I went off roading sunday stopped and turned it back on and it was fine and has been fine today!! Weird!!
Thanks for all your help though!
Post by twiss » Thu Oct 10, 2013 9:10 am
Bit of a shake around probably moved some mud around in there ;)
