Project Bodge
Re: Project Bodge
Well after sticking a drill bit through my first vitara rad in the middle of fitting it, i managed to get hold of another one and fitted that this afternoon. It went in pretty easy and has no leaks but has some corrosion on the top seam and kind of looks like it could burst open at any minute. So i might have to start looking for vit rad number 3 quite soon.
Also got hold of a set of bushwacker arches the other day. Although they wont be going on untill i get wider axles.
Re: Project Bodge
Glad you got it sorted marko, vit rad number 3 is here and ready for you mate when you want it, same price as before.
1994 Pick Up Converted Vitara
+2" Springs, Pro Comp Front And Rear Shocks, 31" Marshalls On 8j's, Front Winch Bumper, OMP Steering Wheel And Boss, Bucket Seats, Stripped Out, Black Bonnet With Scoop, Few Dents And Scratches, Little Rust!!!
Re: Project Bodge
Muppet should stay a bit cooler now at least nice score on the arches, careful though they are quite easy to break.
Re: Project Bodge
Those arches are gonna look sweet mate.
- turbo-tom
Re: Project Bodge
arches will look smart once fitted!, did you get them from a bloke called Dan?
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: Project Bodge
One of them is already slightly broke but should be a easy fix. They are the proper arb ones from lowrange so they should be a bit stronger than the fiberglass copies.ScottieJ wrote:Muppet should stay a bit cooler now at least nice score on the arches, careful though they are quite easy to break.
I got them off ebay and by the look of the name and where they were sent from i think they were Sam16v's.turbo-tom wrote:arches will look smart once fitted!, did you get them from a bloke called Dan?
Re: Project Bodge
Not massively exciting but i finally got round to making a new roof linning for the SJ today.
This is the old one that has been in there since i first bought it.
Here is the new one
Also found this leaflet from 1989 tucked up above the rear view mirror
Here is the new one
Re: Project Bodge
Looks spot on.
Re: Project Bodge
Finally made a start on my samurai axles today. First thing was to move the perches. So made a crappy jig, cut the perches off, moved them over, welded them back on. Job done. (on the back one anyway.) Then made a start on making some trusses for it.
Re: Project Bodge
Good stuff.
I need to make a jig just like that to truss mine and add YJ perches.
What size box section is that you are using for that truss. Looks the perfect size.
