Conversion plate
lukey4x4
Conversion plate
Post by lukey4x4 » Wed Aug 21, 2013 5:23 pm
Well got my. Conversion plate today so gunna put it on just checking dew bits , i remove the studs from gearbox and bolt the conversion plate on through the same holes , do i need to tap holes out or do these silverones cut there own thred , thanks
Re: Conversion plate
Post by twiss » Wed Aug 21, 2013 6:42 pm
The bottom of my plate bolts into the gearbox with Allen key bolts that sit flush with the plate itself
Then there are 2 more holes in it that should line up with the existing holes on the engine block
I had to drill out the top bolt holes to match the larger 1600 bolts, but the bottom ones I just used the existing holes and used bolts that bit through the holes...
Post by Jordi » Wed Aug 21, 2013 7:43 pm
As twiss has said.
Remove the two studs out of the gear box and offer the adaptor plate up. It should have two allen key bolts that bolt in where the studs were. Hilding the plate in place. Its a slightly different thread but will cut its own as it goes in.
Drill the top two gear box mounts out to 12mm and use the original vitara top bolts.
The kit should also have two more bolts to bolt the adaptor plate to the engine inline with the original gearbox bottom bolts.
lukey4x4
Post by lukey4x4 » Wed Aug 21, 2013 7:50 pm
Thanks lads yer sorted wasnt quite sure if a had to tap them holes out but sorted now yer it was a bit tite lyk but went through ok thankss.
lukey4x4
Post by lukey4x4 » Thu Aug 22, 2013 8:58 pm
Joined the box and engine today befor work went togeter no bother , if a get time will put engine into moz any advice
Post by turbo-tom » Mon Aug 26, 2013 10:55 pm
like a glove :)
dazerede
Post by dazerede » Mon Aug 26, 2013 10:59 pm
My mate has a 1.6 vit engine bolted to a 1.3 box but has no conversion plate but you can see that the bottom bolt is bent but it works alright for a while
4” calmini lift kit :)
lukey4x4
Post by lukey4x4 » Fri Aug 30, 2013 12:23 pm
haaad to stick a screwdriver in and bend it abit so the bolts sat flush in the plate but part from that spot on
